Question Starting Problems
I have a 2006 S with a manual transmission and 30K miles. I have an intermittent problem. When I insert the key, I always hear the usual clicks (like relays) and the dash activates. Sometimes, when I turn the key - nothing, the starter doesn't engage or attempt to turn and there is no sound (e.g. click) at all. I had the battery condition checked last night and it is fine. I understand that this may be the ignition switch or starter. Is there a starter relay that I should check before diving into the more involved repairs?
Old 04-12-2014, 03:36 AM
one of gods prototypes
bell's Avatar
I'd check the clutch switch on the pedal, pretty common. ...
It's kind of flat looking with 2 terminals on it.
You can jump the terminals to see if it will start but make sure it's in nuetral as if its in gear the car will take off...
Old 04-12-2014, 05:46 AM
Tags
relay , won't start
