need help, please
My son has a 98 Boxster. The module under the drivers seat seems to have become disconnected. (this happened once before) The problem is the power seat will not work due to the module. I need to move the seat about 1 to 2 inches to remove the rear bolts of the seat. There's no room to get to the seat motor(s). Is there anybody out there that can help me with this problem?
Bill
Accrochez-vous bien de vos rêves..........." |
need help
I understand where everything is at. Thank you for the pictures. But I need to remove the bolts from the rear of the seat. But the seat rails are in the way. I need to find a way to get the bolts out to fix the module. The power to the seat cut when the module came loose. I don't want to pay $250.00 to a dealer again.
I believe the pictures are from a 911 or something else. Does not show where the connection is located. I only have to move the seat 1 1/2 inches. I need to do this to remove the rear seat bolts. The picture shows me the connector not where it is located. ANY help out there. Thanks in advance.
Bill
