recycled sixtie's Avatar
Any ideas how serious this is?
Opened up oil filter and found many green flecks. CEL Code 1341 has not come on again but suspect it will in time . Guy.
There is the occasional fleck of metal but is non metallic.....any ideas?
Old 07-16-2014, 06:48 PM
Now in 993 land ...
aigel's Avatar
You mean ferromagnetic. Aluminum and some stainless steel is not ferromagnetic but it still is metal. And it still should not be in the oil and filter!
Can't really see anything in the picture but a blur.
G
81 SC (sold)
Old 07-16-2014, 09:28 PM
If it is green it is probably the plastic timing chain ramps. They'll need to be replaced. You're NOT talking rebuild money and can be a DIY if you research the procedure.
Old 07-17-2014, 05:27 AM
Friend of Warren
Originally Posted by tonythetarga View Post
if it is green it is probably the plastic timing chain ramps. They'll need to be replaced. You're not talking rebuild money and can be a diy if you research the procedure.
+1
Kurt V
Old 07-17-2014, 05:52 AM
The Unsettler
stomachmonkey's Avatar
There are a number of things in the motor that are green including seals.
Considering the issue in your thread here http://forums.pelicanparts.com/boxster-cayman-forum/814941-code-p1341-came-up.html you may want to consider checking the Vario Cam adjuster solenoid. It can have green seals and if they fail could lead to a CEL.
Your timing chain tensioners can also have green seals.
"I want my two dollars"
"Brandon Won"
Old 07-18-2014, 06:38 AM
The picture is not clear, but whatever it is - regardless... should not be there. BTW, why did you open the oil filter?
Old 07-21-2014, 01:44 PM
