ensign83's Avatar
Porsche Crest P0305 and P0303 after new O2s installed
Ordered oem back O2 sensor from PP, and after careful installing I have a rough idle and misfires,
my new=to=me '07 2.7 w/ 81k miles is missing and stumbling after warmup. I've only had it a month, and replaced O2 downstreams on both banks iaw P0431, only got worse...
Now get P0305, P0303, and P0300, and got blinking CEL as I got home and shut her down.
Gonna check plugs and coils even tho posters say it is rarely that; I was careful putting those new oem Bosch downstream O2 sensors in. Dirty Maf? If plugs look fine, what is usually the next suspect? Tank is half full of Shell V-power. Oil Level is at the top, above the upper thin line marker. I do not see a lot of smoke after warmup. I searched the forum, but this seems strange for a coincidence...
VVS Vanos, variocamicon solenoid, Valve lifter solenoid all mentioned here; are they the same thing, that 9A1... part#?
Should I replace the 9A1... sensors, or punt and tow to the busy indie, missing Xmas at Mom's?
Thanks for any input! Otherwise I love this Cayman...
Old 12-18-2015, 05:18 PM
one of gods prototypes
bell's Avatar
You need to see what the fuel trim adaption is doing, if it's adding fuel and going out of range them it is most likely a vacuum leak.....
Do you have a way to scan and look at live data?
Chances are your old o2s are fine. ...
Brought to you by Carl's Jr.
Old 12-18-2015, 06:54 PM
ensign83's Avatar
2 gal overfill
Drained ~2 qts before level got to high mark.
Removed cover and saw mostly dirt; haven't checked a plug yet and it's chilly.
Look for oil in the MAF area and intake next?
Old 12-19-2015, 03:14 PM
