Ordered oem back O2 sensor from PP, and after careful installing I have a rough idle and misfires,
my new=to=me '07 2.7 w/ 81k miles is missing and stumbling after warmup. I've only had it a month, and replaced O2 downstreams on both banks iaw P0431, only got worse... Now get P0305, P0303, and P0300, and got blinking CEL as I got home and shut her down. ![]() Gonna check plugs and coils even tho posters say it is rarely that; I was careful putting those new oem Bosch downstream O2 sensors in. Dirty Maf? If plugs look fine, what is usually the next suspect? Tank is half full of Shell V-power. Oil Level is at the top, above the upper thin line marker. I do not see a lot of smoke after warmup. I searched the forum, but this seems strange for a coincidence... VVS Vanos, variocamicon solenoid, Valve lifter solenoid all mentioned here; are they the same thing, that 9A1... part#? Should I replace the 9A1... sensors, or punt and tow to the busy indie, missing Xmas at Mom's? Thanks for any input! Otherwise I love this Cayman... |
one of gods prototypes
You need to see what the fuel trim adaption is doing, if it's adding fuel and going out of range them it is most likely a vacuum leak.....
Do you have a way to scan and look at live data? Chances are your old o2s are fine. ...
Brought to you by Carl's Jr. |
2 gal overfill
Drained ~2 qts before level got to high mark.
Removed cover and saw mostly dirt; haven't checked a plug yet and it's chilly. Look for oil in the MAF area and intake next?
