Which AOS to use?
I recently bought a 2001 Boxster S with 67000 mi After a moth of driving I have experienced the infamous white smoke cloud at least once. After running up to redline in 2 gears I left a large cloud of oil smoke behind. I am prepared to replace the oil separator BUT need an opinion on which one The original one is available for about $125 vs an aftermarket version about $75 . I would normally buy the oem one at $125 except some of the comments suggest the aftermarket one might actually be better. Anyone here with first hand experience?
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
This is a no brainer; you should be using the latest OEM part number, 996-107-023-04, which you can get at retail for around $97 if you shop around. And from what we have seen, the aftermarket unit is not better, and may not even be as good as the OEM unit.
Accrochez-vous bien de vos rêves..........." |
URO = U Replace Often
exactly my experience over the years but reading the comments on pelican about the part installation made me think otherwise
