Cayman S/ 987 turn signal relay location
My front turn signals do not work, either with the turn signal switch or the 4-way flasher.
Both rear turn signals work, as do the front side marker blinkers.
I am waiting on one of the turn signal bulbs to arrive, then I'll know if it's because the bulb is out, or the turn signal relay is out.
But I suspect the turn signal relay at this point. The reason is that there is no power to the turn signal pin via the turn signal switch. I removed the headlights, and identified the turn signal pins with an ohm meter and a good bulb. Then checked the headlight pin socket, and no power. It's got to be the relay, right?
I'm trying to find it and having no luck.
I'll post a pic of it's location to this thread once I locate it. Thanks.
Old 01-23-2016, 09:02 PM
Hard to believe the relay distinguishes between front and rear.
I'd suspect a wiring or bulb problem.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 01-26-2016, 12:42 PM
You nailed it, Sir.
I suspect both bulbs were bad, even though one of them ohmed out. ????
The bulbs finally arrived and I replaced both. At first, they didn't work. Turning the key off and on again resolved it, but I have no idea why. Now all signals work.
But I STILL would like to find out the turn signal relay location. And I have the feeling that ordering spare bulbs in advance is going to be important on this car.
Old 01-26-2016, 06:32 PM
