Engine Replacement
I need help on the bad engine seals in the 1997, 1998 boxsters . I'm looking at a BOXSTER with a replacement engine(EXCHANGE). Is there a date when Porsche stop putting the same problem engine back in for the fix? Thanks for all of the input on salvage titles!
Aloha |
Wayne Just curious, are you located in Hawaii or Aloha Oregon ??
Craig C. Laughlin |
The new style seal went into production on February 22, 2000.
Jeff |
oil leaks?
What is the symptom of the bad seals?
Is that why I have oil leaks on my 1997? I noticed the biggest leak is from the pan seal, but there is oil coming from somewhere on top of the engine that I cannot see from below. |
engine failures
How prevalent are th eengine failures. Contemplating buying a 98 right now. Low mileage
I guess the new style seals did not help as there are still new ones 03's, 02's etc having them replaced for leaks.
| All times are GMT -8. The time now is 03:23 AM. |
