987 Boxster
goodman770's Avatar
I want to buy a spare key...
Hello everyone...when I bought my boxster it only had 1 key. I'd like to get a spare just in case....I'm always a little nervous with just having one. What is the best/cheapest way to get another key?
Old 03-29-2016, 06:42 AM
The ONLY way is at a Porsche dealer. Show up with your VIN and proof of ownership.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 03-29-2016, 10:22 AM
oh, and also a fat wallet...
Old 03-29-2016, 09:37 PM
987 Boxster
goodman770's Avatar
Thanks guys....saving my pennies now.
Old 03-30-2016, 07:18 AM
Burn the fire.
Brando's Avatar
Oh my god yes. It's extortion what keys go for.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 03-30-2016, 09:52 AM
Administrator
Luccia at Pelican Parts's Avatar
I know some shops can get the key and program it for you. For example, Callas Rennsport in SoCal was able to obtain a key and program it for our Boxster project car. Make sure it's ordered stipulated, which means it's cut for your car by the vin number. Might try giving some shops a call and see what they say. Good luck.
Old 03-30-2016, 12:25 PM
S ECU Repair's Avatar
Also if you are trying to save some money you can get a "Valet/Lighted Key Head" for about $50. (Instead of the full remote with the buttons to open the door which go for about $200)
This won't include the Key Blade, but local locksmiths with the right tools make copies fot about $20.
Then the key needs to be programming which requieres a scanner so that is about $125 depending on where you go.
Specialized ECU Repair
Porsche Bosch Motronic DME Specialists
Free DME Testing for Pelican Parts Members
www.ECUdoctors.com
1-800-328-1425
Old 04-08-2016, 06:01 AM
wannabee wannabee
WIL84911's Avatar
Came up on my search. $186 versus $377 from the dealer. Video is about 4 years old though.
https://m.youtube.com/watch?v=gX4CwZLQiok
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 04-08-2016, 11:45 AM
Cheapest way if you have one working key Remove its id chip and attach the chip inside the dash near the key hole Then get a VW/Audi key blank cut to work the lock. The car will now start because it sees the id chip in the car. This work around hack works best for those with broken remotes and doesn,t fix anything but gives you an inexpensive extra key.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 04-12-2016, 05:33 AM
987 Boxster
goodman770's Avatar
Thanks folks...this was helpful.
Old 04-12-2016, 11:12 AM
This is similar to the problem that I recently faced. I bought a car being promised two keys, which turned into one being lost. The difference is, we had to buy a new OEM (unprogrammed) key.
If I were doing it on the absolute cheap, I would get this: Brand New for Porsche Boxter 911 Cayman 3 Button Key Shell Fob Kit Replacement | eBay Under $16 for a full key, minus the electronics.
You can use the key blank to get cut at the dealer, or send off to a place like https://keysinthepost.com/ along with the VIN.
I would try to Ebay or otherwise get an old Boxster/Cayman/997 original key that has working electronics. Something like this, but only one key: Lot of 8 Porsche Carerra GTS Boxster 911 Cayman 987 996 986 Key Less Remote | eBay
Swap the module to the new cheap $16 key replacement. Then, get both keys re-coded together in your car (dealer: ~$150). This also eliminates the tiny possibility that the old original key might be out there and be able to start your car.
I used the $16 Ebay key to replace the head of my Gen 1 key, after I had the old and new re-coded to my car. Now both keys look like new, Gen 2 keys. Both are lighted, and work equally well. Neither suffers from the Gen 1 key propensity to lock/unlock in your pocket.
Assuming you could get a key to spare its electronics ($40 would be 1/8 of that lot above), you could get it done for $55 + $150 to code.
Porsche retail prices are around $450 for a new key using their materials. Not cheap, but less than half is still good savings.
Old 04-13-2016, 12:45 PM
Booya, here ya go: Porsche Remote Smart Key 911 996 986 Carrera Boxster 2 Button LXP VIM244 | eBay
$65 for new key hardware, cut & coded at your local Porsche Dealer, $150.
Old 04-13-2016, 01:08 PM
