GaryS (guest)
Guest
Posts: n/a
With the tranny out, can I remove the cover from the IMS to inspect it without having to bring the motor to TDC and lock the cams since I don't have the tools.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Transmission Removal - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 05-09-2016, 06:04 AM
Nick at Pelican Parts's Avatar
No, once the cover is removed the tension on the chain will pull the shaft. It has to be locked down before removing.
- Nick
Locked at tdc thru the nose pulley and the cam ends locked also. Do not use the flawed Pelican instructions which refer to locking the crank with bolts thru the crank flange
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 05-16-2016, 02:43 PM
