Guest
Posts: n/a
Is it possible to just remove the flanged shaft that the inner CV Joint is connected to. My cv joint came loose and damaged one of the threads so I can't bolt the new axle and CV joint. I have a 2003 Boxster S.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Transmission Removal - 986 / 987 (1997-08) - Pelican Parts Technical Article |
The stub axle?> Yes. Install a punch between the flange and the trans, then tighten a bolt into the flange to pull it out. I would grab a repair manual. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799. - Nick |
Administrator
Repair manual here: 2003 Porsche Boxster S Convertible - Books & Technical Documentation - Page 1
Tools here if needed: http://www.pelicanparts.com/Porsche/catalog/Tools/DWKS-tools.htm |
