Charlie (guest)
Guest
Posts: n/a
I have a 1999 Porsche Boxster, starts fine runs fine, but after a while running it stalls, trans goes to 3rd and engine comes back to live while diving. Any info would be appreciated. Thank you In advance.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987
Old 08-05-2016, 06:20 AM
Nick at Pelican Parts's Avatar
This could be from a power issue to the DME, possible ignition switch. You can confirm this by monitoring battery voltage to the coils when the problem occurs.
- Nick
