Chappo (guest)
Guest
Posts: n/a
I have a Porsche Boxster and when im driving the doors will unlock and the interior light comes on and both windows power down also if I leave the car I come back to it and both windows are down any clues
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Door Lock Mechanism / Door Handle - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 03-17-2017, 01:19 PM
Somebody is playing a joke on you! Haha, kidding...I have found that the door lock tumbler on the drivers door can do that...I believe when you're driving the door module is receiving a signal from the tumbler to lower the windows and unlock the door. Remove the door panel and make sure that the door tumbler linkage is properly aligned with the door lock module if it is not, fix it, if it is aligned OK then the fault is most likely inside the door lock module.
- Casey
