Angry 2001 Boxster S- Problem
Driving home, temps good and all the sudden big smoke form right rear exhaust. BIG! Blue and white. No leaks and No sign of oil in Water of Visa versa. Runs terrible and won't run under 3300 RPM. Any Ideas what happened.
Old 05-12-2017, 12:54 PM
Projekt Rostlaube
june82000's Avatar
Very common in these, covered quite a bit here on this forum.
Old 05-12-2017, 01:00 PM
JFP in PA's Avatar
Run a leak down test, you may have cracked a cylinder head. Not at all uncommon.
Accrochez-vous bien de vos rêves..........."
Old 05-12-2017, 02:03 PM
Aos ??
Old 05-12-2017, 09:45 PM
Would AOS only blow smoke out of 1 pipe?
Old 05-13-2017, 07:00 AM
Can't find any posts describing similar experience here. Can someone please give me a lead.
Old 05-13-2017, 07:24 AM
Also noted that smoke clears up at higher rpm. Still just right exhaust pipe. .....?..
Old 05-13-2017, 02:15 PM
