SEVENT9
Borrow fan pulley wrench?
Hi guys
Is anyone located in Toronto able to lend me a fan pulley wrench? I don't have one and need to get my alternator off to clean all the crap under the fan shroud. I have one on order but it is taking its sweet time getting here. I'd need it literally for the amount of time it takes to undo the alternator nut!! Here's hoping!! Greatly appreciated!! Thanks Dan
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html |
Uncertifiable!!!
Just take your 24mm socket and grind it down to fit a 1” or larger open wrench. Voila!!!
![]() ![]() Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
SEVENT9
Sorry - I meant the fan pulley wrench:
Uncertifiable!!!
You don’t need that superfluous wrench. If you get the nut off, then the half pulley and shims fall right out.
Johan
SEVENT9
SEVENT9
Uncertifiable!!!
I’ve been able to loosen the nut by squeezing the belt very tight with large plyers and then cranking the nut with a 24mm spanner. Mind you, the belt was then toast.
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 02-05-2020 at 05:51 PM.. |
