Go Back   Pelican Parts Forums > Regional Forums > Canada
Oracle's Avatar
Question Is 10 lbs compression below normal too much?
Hi,
My mechanic told me the compression is about 10 lbs. below normal but equal in all cylinders.
Is this something serious, am I looking into a rebuild?
Oil consumption is normal.
-J
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 07-20-2003, 07:38 AM
It'll be legen-waitforit
stealthn's Avatar
Others might disagree, but if they are all close I don't think it's an issue. Have you had a valve job done on the car? It might make a difference.
What did your mechanic think?
My two cents.
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 07-21-2003, 08:40 AM
Barber Dave's Avatar
compresssion??????
What about a leak down test to determine if it,s the valves or rings.
My understanding is ,put compressed air to each cyl.
Listen at the T.Body or carb and exhaust if you here hisssing then it's the valves
If you don"t and the compresssion slowly goes down it's rings
I am not a expert ,this is my understanding, others will jump in if I'm wrong. I need to do this to my 1.7 as a check of general condition of my engine. Dave
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 08-08-2003, 03:19 AM
mike_the_man's Avatar
You can also pour a teaspoon of oil in each cylinder and do a compression test again. If it increases, then your rings are going, if it doesn't increase, it's a valve problem. I'm no expert either, this is just what I've heard, but worth a try.
Mike
74 914 2.0L
78 VW Gti
82 VW Rabbit
Old 08-26-2003, 04:09 PM
Oracle's Avatar
Thanks a lot for your ideas and suggestions.
I will definitely talk to Marc B. (Alpine Autowerks) about all these suggestions and most likely I'll try them regardless since they're all a lot less expensive than a not-really-necessary engine work.
Thanks!
-J
-Oscar Wilde
Old 08-26-2003, 06:47 PM
Senior Member
Doug Zielke's Avatar
Re: Is 10 lbs compression below normal too much?
Depends on what he considers "normal".
What are the numbers?
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 09-02-2003, 07:19 PM
Oracle's Avatar
I wish I could answer that question but I have not seen any formal report, this was from the previous owner and verbally from the mechanic, he mentioned that it was OK. regular wear but still 100K more miles to go if I take good care.
So I'm relatively relaxed but I guess as everyone else would like to predict or preview any major issues with the car just to be prepared (or call it quits )
Bye
-J
-Oscar Wilde
Old 09-02-2003, 08:26 PM
Senior Member
In that case, I'd get a compression tester ($50) and do some tests myself. That way you'll know what you have, lest any shyster mechanic tries to BS you into needless work.
Old 09-03-2003, 07:29 AM
Oracle's Avatar
I didn't know a compression tester would be that low in price. Do you have any particular brand/model in mind I can buy? I really like the idea of testing this by myself...
Thanks!
-J
-Oscar Wilde
Old 09-03-2003, 01:30 PM
Compression tester
Oracle:
Go to your local friendly FLAPS they should have a selection.
My advice don't buy the cheapest or the most expensive. this is a tool you buy once and have for life. Dave
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 09-03-2003, 03:40 PM
