Cam Tool Needed
Anyone near TO have the pin wrench type tool used for holding the cams while tightening the retaining bolt that they would rent or lend?
I am progressing with my 3.2 engine rebuild, but before I buy that tool (it will only get used for a couple of hours) I thought I'd check. btw - if anyone wants to see the innards of one of these engines (well, at least part of the innards - I didn't split the case) let me know - I will be ready for reassembly in about two weeks.
Bob D. '84 Carrera - MAF, Wong chip, RSR flywheel, ER bushings and other bits, CTR fiberglass F/R bumpers, 7/9 Fuchs, 21/27 TB, 22/21 SB, bunch of other little stuff '74 Fiat X1/9 2021 X5 |
Well, after getting no replies, I now own one of the cam tools, so there is at least one in southern Ontario. You can disassemble the motor without it but there is no obvious way (other than building a similar tool to reassemble.
