Go Back   Pelican Parts Forums > Regional Forums > Canada
mark '87 930's Avatar
GTA machine shop?
I'm fixing some oil leaks on the engine and potentially looking at reconditioning the heads. Valves are in good shap and have lots left on them for a regrind if need be.
Anyone know of a good machine shop in the GTA, one that knows and has worked on Porsche engines?
some pics for you visual folks..
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 12-28-2009, 01:40 PM
Retired Member
Brian 162's Avatar
Try Response Engineering in Whitby.
416-526-3487 Ask for Yarko.
e-mail; yarko.matkiwsky@hotmail.com
He did my engine 2 years ago.
He's very meticulous in the work he does. He will tell you straight up what you need or don't need.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 12-28-2009, 03:27 PM
Used Up User
imcarthur's Avatar
PM Christien. I know he did engine work last winter & he might be able to steer you somewhere.
Ian
'87 Carrera Cab
Old 12-30-2009, 05:36 PM
Puny Bird
Mark Henry's Avatar
Are you doing a full rebuild or just the top end?
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-04-2010, 02:56 PM
Thanks for the responses everyone.
Mark, I am doing top end only. The pistons and cylinders are in good shape, and judging by the condition of the cams and rockers, I am confident the bottom end is good to go.
Primary reason for the 'rebuild' is to fix oil leaks, which was coming from seemingly everywhere.
Getting there. Parts are ordered and heads are off for reconditioning. I presume rebuild will start the end of January. Hopefully all parts will be cleaned by then and ready for reassembly.
1956 Chevy 3100
Old 01-04-2010, 03:17 PM
Puny Bird
Mark Henry's Avatar
Cool I just was wondering if you wanted to split on sealants if you were doing a full build.
Old 01-04-2010, 03:48 PM
Mark,
Sealants are certainly not your most expensive piece. Threebond 1194 (formerly 1104) is inexpensive and available at motorcycle shops mainly (I bought mine locally in Etobicoke). Loctite products are available at Brafasco and not to bad in small quantities. Curil-t you have to get from the US as far as I saw, just order it with your parts.
1956 Chevy 3100
Old 01-05-2010, 12:05 PM
Mark, I used Brent at Whaletail in Milton to do mine. He did a very nice job.
Joe,
Old 01-07-2010, 07:39 PM
Puny Bird
Mark Henry's Avatar
Joe,
Thanks, but I've put together a couple before in the 90's, I've also built the odd VW engine before.
I have a 120HP Type one engine in my '67 VW bus. I'm building a matching '67 bug 1700lbs with a 180hp (estimated) 2.7 liter nickies, SDS FI 914 type 4 for in it. I built the heads, installed new guides and seats, oversize valves, 12mm plugs.... 2nd engine I've built like this first was 150RWHP on a chassis dyno.
I think I can handle it.
Just didn't want to buy a bunch sealants I'll never use again, I have enough half full tubes and bottles.
Old 01-07-2010, 10:55 PM
