Go Back   Pelican Parts Forums > Regional Forums > Canada
TDIDog's Avatar
Transmission- Transaxel Rebuilder
Anyone know a good, trustworthy transmission- transaxel re-builder in B.C.? Preferably on Vancouver Island. Someone that can set up backlash etc.
jack
Old 09-05-2010, 09:42 AM
I took my 915 to a guy in Port Coquitlam to rebuild. When I realized he didn't know that the first gear synchro hub ring and the first gear were two parts and that they came apart I took it all back from him in about 30 parts and took it all in 4 boxes down to John Walker in Seattle and he fixed me up at a very reasonable price. I would not hesitate to deal with him again and it was worth the trip. I wish I would have taken it to him in the first place.
"Charlie don't surf!"
Old 09-05-2010, 04:17 PM
Puny Bird
Mark Henry's Avatar
I can do it, but I'm on the wrong side for you.
I've also heard good things about John's work, might be your best bet.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 09-05-2010, 06:17 PM
TDIDog's Avatar
gearbox
Have a contact number, just incase? I have someone that can do the tranny, but not the set up the ring & pinion. That needs to be replaced on mine.
I'm looking at a used tranny first. Just not sure what I will end up with.
Thanks for all help.
cheers
jack
Old 09-06-2010, 12:16 AM
Somatic Negative Optimist
Gunter's Avatar
Hands down: JW in Seattle.
You want to do it right the first time and not end up removing it again for a while.
Old 09-16-2010, 08:52 AM
TDIDog's Avatar
Tranny Builder
Tried him. Wont take my calls. Was going to send me a quote, but haven't seen anything yet. I guess I must have pissed him off.
Old 09-16-2010, 08:40 PM
Gunter's Avatar
He's busy.
Try again e-mail and phone.
John is very easy-going.
If you ship it, make a solid crate because he hates to have to repair a flimsy one.
It's not going to be cheap. The parts cost a lot whoever is doing it.
Old 09-17-2010, 08:53 AM
TDIDog's Avatar
I know it's not going to be cheap. Would still like to know what the cost will be. I would like to be able to ask questions if I'm spending that kind of $.
Old 09-17-2010, 11:33 PM
andrew15's Avatar
Part of the problem is he's not going to know what it needds until he gets into it - if it needs a new R&P, it's going to add at least $1,000 same with gears with chipped teeth, etc. If you get a quote - expect a low/high range of $3,000 to account for broken / damaged parts inside
Unfortunately, transaxles are one of those things you can't really give a solid quote on until it's open.
That said, JW is a solid guy and would be on my short list to rebuild my 911 transaxle.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 09-18-2010, 08:44 AM
TDIDog's Avatar
I'm sure he is busy. I left at least 3 messages & emails over a week ago, and have yet to get a response. I'm not calling him again.
Old 09-18-2010, 09:18 AM
Puny Bird
Mark Henry's Avatar
What one is it?
I've only done 901's (and a bunch of bugs) and they are not too bad. If you have two cores I can often make one out of the two. Stack service labour isn't that bad and is often all it needs, but if I have to set the R&P it doubles the labour cost. First gear slider is expensive but I have a couple of good used ones. Bearings, sliders, dog teeth and brake bands are what usually goes and if you have to buy them all new it will get expensive.
I have a rebuilt 914-901 in stock.
I've never done a 915 but I hear it's just a larger version of the 901 and you can use the dog teeth out of a 944 (or is it 924?). But I've also heard that often the case is trashed. I have no parts at all.
Andrew is right, it's imposable to do a quote till you tear it down. If you were asking JW for a nailed down price before you shipped that could be part of the problem.
I don't want to do a later trans.
Old 09-18-2010, 10:32 AM
If you are going to crate it anyway then the only issue is shipping.
If you send it Greyhound it will be cheap, so find a good rebuilder and send it there.
I'm too busy right now.
Old 09-25-2010, 06:50 AM
