Retired Member
Winter Projects
What are your plans??
Mine are: 1. new shocks front and rear - Bilstein sports. 2. replace the front suspension bushings and mono balls - Elephant Racing products. 3. picked up a rebuilt steering rack that I will put in while the front suspension is apart. 4. spacers for rear wheels - lower priority. 5. lower the car just a little. 6. check the clutch. Got some 50,000 kms on the clutch and it has a really soft pedal feel starting this summer. I adjusted it to spec, but no change in feel (cable, fork, bearings all new when clutch replaced). I will check the return spring and pedal cluster this winter. If I find nothing, I will run it until she slips. 5. usual maintenance stuff - oil, valve adjust, check brakes and flush fluid, adjust front wheel bearings, check all under carriage bolts for tightness and inspect tub for possible cracks. 6. if I have time and the weather is OK, power wash the underside of the vehicle. And, home reno projects - foyer, dining room and living room this winter. Hmmmm......I can honestly say I prefer getting P-car grease under my nails!!
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
- paint blue car silver.
- build 2.4 for yellow car - tune 3.0 in blue/silver car maybe..... - paint red car green - build 3.2 for blue/silver car -put 3.0 in yellow car- 2.4 into red/green car seems like a short list
UnRegistered User
I like the colour of the blue car now. There is something about it that is just right...
I also really like silver on a 911, what paint are you using for this? Factory colour? I have lots to do, but too little time.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Somatic Negative Optimist
I did everything necessary that needed doing before the cold sets in, I hope.
![]() Winter Project: My annual trip to Waikiki for an open-air gathering of sun-worshippers and Atheists. On Sunday Mornings, some self-appointed Prophets have somehow obtained permission to put up loudspeakers near the beach so the non-believers have to endure an open-air performance of local bible-freaks spouting nonsense about the afterlife, hell and damnation for the sinners. While these Gurus cite nebulous scriptures and claiming a direct link to fictitious Gods and Saviors, several volleyball clubs are active on the beach and bring their own music to purposely drown out the BS from the soul-savers. It’s funny and we laugh a lot.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
First finish house reno's so I can sell the house next year!
As for the car. 1) Front hood and rear deck lid shocks 2) Front bumper turbo S ducts 3) Clear turn signal markers 4) Muffler bypass pipes 5) Pollen filters and if I am feeling adventurous.... 6) Spark plugs 7) Fuel and air filters 8) V-belts 9) Front diff. and transmission oil change (a lift would help) Might wait till spring for these to get some help from fellow Pelicans .
1996 993tt Arena Red/Classic Grey -"Looks like I picked the wrong week to quit sniffing glue." |
Retired Member
I was holding back, Charlie, because I was in a good mood.
![]() The Assembly of the Sacred Palm also sells coconuts and pineapples blessed with clorinated holy water. Let me know if you want one. That is a long list of projects, Charlie, especially for the suspension. A lot of work, BTDT. Keep in mind that new gas shocks tend to push the height up about 3/4" in the rear without any other adjustment. There is a little trick to installing. Keep them compressed until in situ and the lower bolt is in. I'd check and make sure there is lots of Moly grease in the rebuilt S. Rack. After everything is installed, where are you planning to go for alignment and cornerbalance? |
I found it relatively easy to use a hand pump with a 1/2"? nylon line that came with it to get new Mobil 1 Delvac 75W90 into the G50. Engine oil and filters: Impossible to do without the correct filter wrench. Plugs are a real adventure. ![]() Where are you getting the Pollen filters from?
Retired Member
I have talked Al into assisting (requires food and beer) with ride height, string alignment and corner balance. I will go to a local shop in Langley for the final alignment. Alignment will be to Anderson recommended specs.
That's a lot of work for just Food and Beer.
![]() Tried a few different settings until I was happy with height etc. Took a few years. What does Anderson recommend for: Camber front & rear? Toe front & rear?
Alps Adventurer
Nothing major, but to name a few...
Retired Member
Euro ride heigth is 25" at rear fender lip and 25.5" at the front lip. This gives a slight nose-down attitude. I'm slightly higher than this right now so the plan is to get to these number and maybe 1/4 to 3/8" lower. I can't go too low because of my steep driveway.
As for alignment settings.....Bruce Anderson recommends: Front camber 0 degrees negative +/- 10 min caster at 6 degress 5 min +/- 15 min toe-in +15 min +/- 5 min not pressed or 0 deg pressed Rear camber 1 degree negative +/- 10 min toe-in +10 min My last alignment was close to these but the strut brace limited adjustment. I will be modifing the brace to allow more adjustment.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. Last edited by Charlie V; 11-20-2010 at 02:37 PM.. |
Alps Adventurer
Pelican, as I do with all my Mahle brand filters (both oil, air, fuel and cabin air). They are the same units as the ones from Porsche.
As for an oil filter wrench, the one from BMW for oilhead motorcycles fits perfectly...which I already happened to have. |
Formerly known as Syzygy
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Puny Bird
Finish my 914 3.0 coversion, build the 3.0 with 9.7cr RSR spec malhe pistons.
Finish my 67 bug, all ready and I have 99% of the parts, but needs full assembly.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Your driveway restricts your height. Otherwise you may want to go 1/2" lower overall with the bump-steer spacers installed. I found that a 1/2 - 3/4 deg negative Camber front and 1 - 1.5 deg rear makes the car slide equally in the curves; almost a 50/50 distribution, very nice.
Engine oil and brake fluid were done before storage. I heard plugs were knuckle busters! The pollen filters are either coming from Pelican or ********az. I have a friend who lives in Arizona and is coming north for Christmas so she might bring some goodies from ******** for me. Did you want a set of pollen filters?
Yes, I have LSD.
Here are some answers from the experts: Transmission oil question for 993 - Rennlist Discussion Forums It seems that Delvac is alright but it also appears that some people report better results with other oils. 993's can have Dino or Synthetic 75W90 according to the driver's manual. Would love to hear from someone who tried both and found one or the other better or worse for smooth shifting? Trial and error? Thanks for the offer. Pelican sells the pollen filter for $20.- ea. What puzzles me is the cost of ignition rotors: $31.75 ea. ???? I notice Pelican blocks out competitors on your reply.
Alps Adventurer
Strange that one gear lube would work so well in one owner's 993 and not so well in another owner's 993.
If my 928S4 5spd was up and going I'd be on a WInter Gt. but guess not this year with work.
