fixing tach in Canada
A couple of the light bulbs have fallen into my Tach. Does any one know of a shop in Canada who can open the tach to remove the bulbs? I don't want to send it to NHS for such a simple task. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
I patiently extracted a lightbulb once using a cotton swap with sticky tape on the end , but it took forever to line up the bulb with n accessable bulb holder
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
<insert witty title here>
If it's like speedo, it's really easy to open up. I had mine open in a few minutes with no special tools at all. I can't remember the exact procedure, but it's fairly obvious once you have it on the workbench.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Retired Member
You need a really small flat head screwdriver. Insert it between the tach base and the trim ring. Very carefully pry the ring from the base. Pry a little at a time working around the tach. Eventually the ring will expand enough it will come off.
Installation is easier. Once the lens and cap is in place use a very small hammer and just tap the ring tightly to the tach base.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Puny Bird
Philip as others have said it's not that hard. If you don't want to tackle it just bring it with you when you come down and I'll fix it for you.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Maybe I'll...
give it a try. Just didn't want to fuch it up.
Thanks for the input guys.
83 911 Production Cab #10
Phil
Just bring it next time we go Chinese, since you'll be buying, my first 30 minutes is free ![]() Back home next week-end, you guys would not believe the chaos in the UK when they get an inch of snow ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Alps Adventurer
440 flights cancelled at Heathrow cancelled... Good thing I was not coming back that week-end.
London snowstorm pits British Airways against Heathow by Skift
