Go Back   Pelican Parts Forums > Regional Forums > Canada
Lightbulb engine build question
I am just getting my ' 82 S/C project on the road, @ need some opinions/advice. 3 litre engine is stock except for catalytic converter delete @ removing cis injection @ fitting 40 mm PMO carbs also recurved distributor @ blaster coil with cap. discharge c/d box . I want to pull motor in the spring to reseal @ change exhaust ,add hyd. tensioners and MAYBE put in some warmed up cams. what is the best grind to use with stock pistons ? compression is good , I don't want to pull the heads off just yet. thanks for reading ,anybody else done something like this? norm s
Old 12-05-2015, 09:10 PM
It'll be legen-waitforit
stealthn's Avatar
i put in new 964 cams in my 79, ran fantastic, crbs would have been the other thing that would have added more performance.
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 12-06-2015, 05:25 PM
pors1968's Avatar
964 cam carb tune for 3L (34 venturie) SSI exaust and check for brooken head stud .You should be good for 225 hp.
Old 12-07-2015, 10:55 AM
Puny Bird
Mark Henry's Avatar
Sorry I didn't see this earlier, but the cams will cost you at least $1000 plus, so I'd get DR cams and let him suggest the grind.
But beware he did have issues a while back, so I'd make damn sure he's back on track before ordering.
WEB cams are good, but you basically have to make your own selection.
Elgin cams are also an option, bit cheaper but often more conservative grinds.
Be aware that cheap/deal cam sets can be reground on the base circle, resulting in rocker geometry issues... Or just end up being a horrible grind for your engine combination.
Most will want your old core cams, the core charge can be quite high compared to the shipping of your cores.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 12-27-2015, 10:12 AM
