-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Adjust camber R53 2005 convertible (http://forums.pelicanparts.com/showthread.php?t=1035629)
jlepe 07-25-2019 03:40 PM
Hi, everyone.
I hope somebody can to help me. Two month ago, when I was driving the tire fell down in a hole. I had to change front control arm and shocks struts. However, something happened that now the car has positive front camber. I listened there is not adjustment to correct front camber on Mini's.
Please, what I can do to fix the front camber?
Thank you.http://forums.pelicanparts.com/uploa...1564094356.png
Dmitry at Pelican Parts 07-25-2019 03:58 PM
Hello and welcome to the forum! Take a look at the link below to make sure that the control arm install was done properly - once confirmed, you can have the alignment shop do the final adjustments. Let us know if you have any other questions or if we can assist with any future part needs.
https://www.pelicanparts.com/techarticles/MINI/50-SUSPEN-Adjustable_Rear_Control_Arm_Installation/50-SUSPEN-Adjustable_Rear_Control_Arm_Installation.htm
jlepe 07-25-2019 08:56 PM
Thank you for the comment. However, the problem is front, not rear.
