Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Adjust camber R53 2005 convertible
Hi, everyone.
I hope somebody can to help me. Two month ago, when I was driving the tire fell down in a hole. I had to change front control arm and shocks struts. However, something happened that now the car has positive front camber. I listened there is not adjustment to correct front camber on Mini's.
Please, what I can do to fix the front camber?
Thank you.
Old 07-25-2019, 03:40 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! Take a look at the link below to make sure that the control arm install was done properly - once confirmed, you can have the alignment shop do the final adjustments. Let us know if you have any other questions or if we can assist with any future part needs.
https://www.pelicanparts.com/techarticles/MINI/50-SUSPEN-Adjustable_Rear_Control_Arm_Installation/50-SUSPEN-Adjustable_Rear_Control_Arm_Installation.htm
Old 07-25-2019, 03:58 PM
Thank you for the comment. However, the problem is front, not rear.
Old 07-25-2019, 08:56 PM
Tags
2005 , camber , convertible , r53
