Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
No fuel pressure, no codes
I have a 2008 mini cooper base with no engine codes, it has a new timing set up and a fresh valve job. New crank sensor, Vanos solenoids, and fuel filter. After doing the timing chain replacement, the car started but only ran off idle, then it stopped running all together and there was no fuel pressure at the rail. I checked the fuel filter and ended up replacing it. I then noticed a bent valve so i pulled the head and after replacing 10 valves, I found a vacuum leak and replaced the hose. The car still has no fuel pressure yet I can hear the pump running and it has correct voltage.
Any help or advice would be greatly appreciated. My wife wants her parking spot back!!
Old 09-22-2019, 06:56 PM
