Guest
Posts: n/a
Wonderfull article. It's just a shame I found it after I've completed my clutch project. I, like Mark mentioned, did not have to remove the heat sheild or starter either. As a matter of fact no intake manifold or components were dismantled to acheive my task as well. I did find it helpfull, after studying the situation, to just take a little more time and remove the entire radiator support. It drasticly helps with the Eng. /Tranny removal. Take your time. Double check everything. MED
![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Replacement |
Author of "101 Projects"
Thanks for the kind words on the article. On some of the early cars there are some differences in the clutch replacement, so you may have to use a bit of trial and error to figure out what you need to replace and/or remove. I'm going to copy your comments here to the forums and perhaps some other people may have additional suggestions for other people about to try this task.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
BMW clutch provides a lavishly comfortable ride. Yes i am agree with wayne, First we have to find out the problem on clutch. Generally in clutch replacement we replace 3 pieces: the pressure plate, clutch disc and throwout bearing.While you are replacing clutch it is recommended to replace the pilot bearing too. Other parts like the fork, pivot spin, guide tube, etc. will so long-lasting so you don't really have to replace them. If after this you are not able to replace clutch than you can contact expert BMW Repair Dallas from 972- 351-8964
