Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
r53mini (guest)
Guest
Posts: n/a
I'm replacing the pump with a Walbro unit. wonder if you think the pump inlet should sit down on the tube attached to screen at bottom of pump housing? The OEM pump seems to have two inlets on the bottom: one that draws thru the tube bypasses screen, and another that draws perhaps thru the screen.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-16-2013, 05:27 PM
Nick at Pelican Parts's Avatar
There should not be an line that bypasses the screen. This could be the pick up tube from the other side of the tank since it is a saddle tank design
- Nick
