Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
HelpMePlease (guest)
Guest
Posts: n/a
Replaced master and slave separately. On one occasion, after bleeding and letting it sit with pedal pressed all night, I could get it in gear but clutch engagement was still very low. The next morning I was back to not being able to get it in gear at all. Mechanic said the arm coming out of the transmission shouldn't move at all by hand and he's able to pull it out by hand a little after the pedal is depressed. Is this normal? Pedal feel seems ok. Slave plunger is moving probably 1.5" or more but no clutch release to allow gear change.
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-25-2015, 05:41 AM
Nick at Pelican Parts's Avatar
That is likely due to the slave not fully engaging the lever. There is likely air trapped inthe system.
- Nick
