Guest
Posts: n/a
Question.have fitted new clutch,master cyl and slave to my 2004 Cooper,have bled system manually and with pressure bleeder and have good pedal with bleeder attached,as soon as bleeder removed unable to select 1st smoothly and reverse crunches any ideas? Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
It still needs bleeding. Very common for this to take some time. Once you pressure bleed it, try helping the slave extend as you manually bleed it.
- Nick |
