Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
GregV (guest)
Guest
Posts: n/a
My 2005 MCS slipped out of 6th gear into neutral and now wont go into any gear. Shifter moves fine through at the gears and clutch pedal feels normal, but transmission wont engage. Just changed cv axles last week and car has been running beautifully.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Shift Cable Replacement
Old 11-11-2015, 09:40 AM
Nick at Pelican Parts's Avatar
Check if the cables are moving the shift levers at the trans. If so, check that an axle hasn't popped out of the trans.
- Nick
