Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Kevin (guest)
Guest
Posts: n/a
Do you have a similar article for r/52/53? I've a leaky seal on passenger side after 6k miles on a new cv axel ... Tiring to determine if this is doable without dropping the trans to get it done.
Thanks!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Drive Axle Seal Replacement
Old 12-22-2015, 05:58 AM
Nick at Pelican Parts's Avatar
We don't currently have that tech article. If we get a chance to perform the procedure, we will be sure to document it.
I would grab a repair manual. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
All R52 articles are here:
http://www.pelicanparts.com/techarticles/MINI/MINI_tech_index.htm#basics ] http://www.pelicanparts.com/techarticles/MINI/MINI_tech_index.htm#basics [/url]
- Nick
