Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
MiniC (guest)
Guest
Posts: n/a
I have a mini cooper R56, it has become hard to shift gear. It is ok going up gears over to the right but when im shifting back down mainly from 3rd into 2nd it is hard to move left, once it is over to the left it goes into gear fine. This only happens after approx 12 miles of driving each day and also when the engine is off it will remain stift untill engine is cooled down.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Manual Transmission Oil Change
Old 02-12-2016, 06:27 AM
Nick at Pelican Parts's Avatar
I would start by replacing the fluid. If that doesn't help, the trans may be worn.
- Nick
