Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Chris (guest)
Guest
Posts: n/a
Im having issues removing the splash guard to check the master cylinder. The bolts are slightly rusty, but when I try to turn they just spin and do not remove?
Any idea's?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Master and Slave Cylinder Replacement
Old 03-11-2016, 09:47 AM
Nick at Pelican Parts's Avatar
Try grabbing the back side with needle-nose vise grips. If you can't, you will have to break it and replace the parts. Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
