Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
JD (guest)
Guest
Posts: n/a
The auxiliary belt got shredded on my sisters 2003 Mini Cooper S. I have replaced it with a new one, but noticed a crack forming on the crank pulley you call it harmonic balancer here during the belt replacement. I have also noticed there was NO bolt holding the balacer in place on the crank that shocked me. I still installed the belt and started the engine. It seems fine other than visible wobble on the balancer that may well have been the cause of the belt breaking over time of excessive wear from its wobble. I popped here just to confirm there should have been a bolt securing the balancer and there is, so I was correct to suspect it somehow fell out. I guess I need to order a new bolt and keep the balancer secure and hope that solves its slight wobble. At the very high cost of a new balancer, I will keep an eye on it and replace when that crack starts to deteriorate to a point it makes noise or symptoms it is failing.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Crankshaft Pulley Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 11-23-2016, 08:32 AM
Nick at Pelican Parts's Avatar
yes, get a fastener for it. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Absolutely. You'll also want to replace the crank pulley (harmonic balancer) if there is a visible crack forming on it. Figure 6 in that article shoes what can happen with it when it wears.
Crankshaft Pulley - 2003 Mini Cooper S Hatchback - Engine Miscellaneous - Page 1
Crankshaft pulley bolt - Pelican Parts - Crankshaft Hex Bolt
Torque the bolt to 115Nm (85ft/lbs.), which is covered in figure 8 of the article.
Old 11-30-2016, 09:43 AM
