Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Alex (guest)
Guest
Posts: n/a
Do N14 turbochargers have a serviceable internal seal. I've see some oil inside the intercooler pipes which potentially points to an internal turbo leak, but not sure if there are other reasons for oil there. The oil feed line is not leaking. I've serviced this seal in another turbo car I owned but I've never seen the part advertised for my 2008 Cooper S. Thanks!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Oil Consumption Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 08:07 AM
Nick at Pelican Parts's Avatar
The turbochargers don't have a rebuild kit as far as I know. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
You might want to give a shop a call that does turbo rebuilds. They might be able to rebuild yours. Can call a local MINI indy shop in your area and see if they can recommend a place for you.
Old 04-25-2017, 11:16 AM
