Guest
Posts: n/a
hello, I have an 07 mini S-R56, my mini lost power misfire thats what the code said, so I replaced the ignition coil, tested again and it said the same thing but a diferent coil now, so I replaced it, and. now its telling me that its another coil, not sure what to do now, I have not replaced the third one yet I replaced the valve cover gasket seals and checked all lines, now I'm hoping it reads different please help----thank you in advance pelican team
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
To pinpoint the cause of the misfire, I would check spark, fuel and compression on all cylinders.
- Nick |
Administrator
What is the exact P code you pulled? P0300? Or was it a misfire on a specific cylinder? Did you clear the codes after replacing the coils?
