Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Jeremy (guest)
Guest
Posts: n/a
Hi, I have a 2006 Mini Cooper S, and the battery is completely shot and needs to be replaced. How do I know if the computer will need to be reset after replacing the battery?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Battery Replacement and Battery Tender Installation (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 05-09-2017, 06:46 AM
Nick at Pelican Parts's Avatar
if the negative terminal has electronics on it, you will have to register the new battery.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
I don't believe the R53 came equiped with the IBS unit. You can always check by looking at the negative battery terminal. The R56 is what came with or even with out the IBS modules. Info on them here: MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-11-2017, 11:31 AM
