Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mini Cooper 2002. Steering is heavy
My Mini Cooper 2002, steering has become heavy. Any ideas what could be causing it ? Thanks.
Old 04-10-2018, 09:34 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! It could be the power steering pump has gone bad - I'm attaching a link to a DIY tech article from our site on this replacement procedure. Other members may also chime in with their expertise. Hope this helps you a bit and best of luck!
https://www.pelicanparts.com/techarticles/MINI/47-SUSPEN-Power_Steering_Pump_Replacement/47-SUSPEN-Power_Steering_Pump_Replacement.htm
Old 04-10-2018, 10:24 AM
Thanks for the quick reply, I will check it out.
Do you know if this is an MOT failure in the united kingdom ?
Old 04-11-2018, 12:20 AM
