Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
JTH JTH is offline
2010 mini base model P0597
Just replaced the t-stat - filled system w/ Airlift so no air bubbles- P0597 won't clear.
voltage at t-stat connector sytem voltage on 1 pin- 3.5V on the other pin which I believe is pulse width modulated. is there a resistance reading for known good t-stat? old one measures 6 M ohms. Thanks JT
Old 04-07-2018, 10:00 AM
Administrator
Luccia at Pelican Parts's Avatar
I'd check over your harness to make sure it isn't damaged: http://forums.pelicanparts.com/mini-discussion-forum/939966-question-coolant-temperature-oil-pressure-sensor-replacement.html.
Old 04-14-2018, 04:47 PM
