least common denominator
The mystery of USB
Yes I am a tech but in my naivete I just presumed all USB was backward compatible. So I bought one of those all in one PC's because space was tight. It is pretty cool except the USB ports are on the back, no biggie just get a USB hub to put the ports out front right? Don't care about the mouse and keyboard but also don't want to go hunting around the back of the monitor every time I want to transfer files with a thumb drive.
I asked this question on the internet and started a firestorm, yes, yes, yes, NO!, YES! Thing is we have a drawer full of USB drive some of which could go as far back as 1.0. And yes I now fire wire is better , blah, blah, blah...
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Platinum Member
I've never had an issue plugging in an older USB drive.
Won't hurt to try it.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
You do not have permissi
Windows7 won't recognize my SSD external drives plugged into the front.
Have to plug them into the 2.0 port in back. (part of the motherboard) For flight sim gaming I also use a few splitter-extenders for USB hardware (mouse, keyboard, speakers, joystick, throttle, pedals, TrackIR, plus a few HDs, etc). I kept crashing during FSX RedBull air racing until I switched to external view and realized the throttle was also controlling the rudder but that was fixed via game software settings. The USB assignments gets confused sometimes and the OS will start looping into connect/disconnect mode if they are not arraigned in a certain order.
Meanwhile other things are still happening. |
Read this online:
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
There are the "low" and "high" voltage/amps
Front ports are usually low voltage so you can't use things like a Hard Drive or a USB hub (unless has a separate power source). Those USB ports with Blue inside (if the manuf. followed standard) are 2.0 or 3.0 and supposedly are "high". USB ports on Laptop are a crapshots, you never know what you got... until you try to use it. Problem lies that manufactures do as they wish and not follow any best practice
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
The Unsettler
Yup
USB ports can supply differing levels of juice. The front “convenience” ports are usually low power suitable for keyboards and mice but not drives or hubs.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Un Chien Andalusia
USB
Only one way the plug will work Two possible ways the plug could go in Always takes three attempts to get it to fit
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
Almost Banned Once
... and why does Windows have to reinstall a mouse or key board if you plug it into a different port?
USB-C is a whole lot easier/better. You can plug it in either way.
- Peter |
Burn the fire.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Apply a dot to both w/whiteout.
Match dots. Done.
Band.
1983 SC Coupe 2020 Macan Turbo 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
