W126's? Diesel content
Any of guys own(ed) one?
I just looked at one owner high mileage 300SD with maintenance records since new. It has peaked my interest in these old Mercedes diesels...
dolor et pavor Copyright Last edited by Arizona_928; 01-05-2019 at 04:09 PM.. |
Banned
I’ve owned every edition of w126 diesels, 5 and 6 cylinder, long and short WB, etc. What do you want to know?
How many miles do those om617's last. High failure parts?
dolor et pavor Copyright |
Banned
They are very durable engines but the lifespan of one depends very heavily on how well they are maintained, just like every other engine ever made. People love to crow about them being "500k engines" but I've seen them fail w 100k miles. Poor maintenance can really kill a diesel, any diesel.
With reasonable maintenance, they go a couple hundred thousand miles before starting to lose some compression and develop blow-by. In fact, the most important test to do on one you are considering is to open the oil cap with it running and see how much wind comes out. You should be able to lose the cap and it should stay in place w the engine idling. If an OM617 has good compression, it can be made to run and perform like new w other tuning and maintenance items performed. There are not really any high failure rate parts in the engine but for the rest of the car, there is the usual laundry list of things that go bad on an old German car from the climate control to the vacuum system to interior pieces to... The good news is that they are not too bad to work on and parts are still widely available. Post some pictures and more info about the car here and I'll watch the thread and offer my input. |
Cars and Cappuccino
The old skool guys will say the w123's were the last of the REAL Mercedes diesels. (they are are the preferred civilian taxi vehicle in most war zones). I own an w212 and still really like it after 80k miles. Even though the oil cooler seals recently failed and it puked a couple quarts onto the driveway. 39 mpg on the highway and tons or torque.
![]() This one is in the sweet spot. Pre-EGR turbo diesel technology with bullet proof early diesel DNA. https://www.cargurus.com/Cars/l-Used-1980-Mercedes-Benz-300-Class-300SD-Turbodiesel-t55414#listing=226726280
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) Last edited by tdw28210; 01-06-2019 at 04:11 AM.. |
I've never owned or worked on a W126 Diesel (only the gas model), but this chassis is one of my favorite cars, so looking forward to seeing pictures and specifically the model that you are interested in.
Ole Skool - wouldn't have it any other way |
Banned
All of the old iron head diesels were good motors but technology has really left them behind. I drive a 2006 Jetta TDI that is just light years ahead of those cars in any possible metric of measurement. Performance/efficiency/quietness/emissions/etc. |
I bought the one I was looking at. 1984 300SD. No blow by, no smoke. Some issues that didn't present itself until I got home. I'll go through it and post some questions when I get a chance to one over everything.
shh-the robot is sleeping
I have owned 3 diesel Mercedes. Dealer incorrectly ids it as an SD - it is a w123 NOT a 126. Not sure how much I would trust their aditional insight past this. This example from the pics needs both front seats rebuilt. Figure $1k each. Poorly glued on interior wood trim unfortunately has destroyed original and very expensive to replace pieces. Paint on roof is toast and likely is or will soon be on others surfaces. They very carefully mention body area rust thus dismissing undercarriage issues. Rust on the rail is only mentioned. Invariably This is accompanied by front and rear quarter rust and rust on vital unibody components.
Sure the engines are strong. But contrary to internet lore, they do not last forever. Valves, heads, injectors etc... often go an require big dollars to repair. If you bought this car new in 1980 and took prefect care of it, it would do many hundreds of thousands of miles. Now, it is an old piece of highly engineered machinery with an uncertain past. Similar to an old 911, you need to love it and DIY or have an open checkbook for someone else to do this. TMU... Way over priced but a clever attempt to mislead an unknowlegable person. Pass on it and check out the w123 forums. If you wanted to diy... maybe offer $4000
'88 911 Coupe, 69k miles Last edited by da Vinci Dan; 01-06-2019 at 09:41 AM.. |
Cars and Cappuccino
![]() https://classics.autotrader.com/classic-cars/1980/mercedes_benz/300sd/101033655
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Banned
I had a '79 for a DD for years, let me see if I can dig up some photos.
Banned
My ride:
I still see this car once in a while, sold it to an acquaintance. Rare color combo.
I great up working on them, some good memories. Not much interior room considering how big they are but they are great highway cars. Glow plugs, injector lines, valve adjustments, oil pan gaskets... used to do that in my sleep. Make sure you know where the engine kill in, door lock actuators will fail.
![]() Cool cars, dont see many around here anymore. |
Cars & Coffee Killer
I still miss my 300D...
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
![]() here's the land yacht. Only issue I've found was looks like a fuel damper bolt. Little shaky at idle when hot. pelican has one for 35$ so I'll order one tomorrow. 300k mi, with no blow by, or smoke. Gonna be a keeper.
Cars and Cappuccino
Those bumpers make the 911 black globs look dainty.
and those cat-eared headrests are still awesome.
You a rapper now!
Seriously, cool car. The quality of the old MBZ is great. We loved our W123.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Who would want to own an old Benz..........................................Oh, never mind!
Von http://vonsmog.com 73' 911T Coupe, 76' 911S Targa 73'& 80' Mercedes Unimog DoKa 59' Austin Healey 100-6 |
Oooh... Always had a soft spot for the wagons.
