Wire cut to short
Any advice on how to strip this wire back to attach a new light fixture. This is for a wall sconce and the original thought was to get rid of the fixture. However....after the project she decided to keep it. There isn't any slack in that wire to pull it out any more. Any suggestions??
Make Bruins Great Again
Cut the sheetrock, put in a junction box, splice in a longer wire, patch the sheetrock.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Why not use a wire nut and a longer piece of wire.
Strip the line and use a piece of wire and wire nut them together. Basically turning the existing box into a j box |
Not sure I can get in there to strip it. My digits area not so long....
Can you pull the wire from the bottom of the box, strip and feed back through?
In the pics it seems the drywall isn't overly close the box. How bout a razor knife to cut the outer insulation, nice in easy not to go through the insulation of the individual wires, then uyou can separate the 3 wires and strip independently with the razor knife. Wire nut and added wire (×3) Last edited by freeform911; 02-13-2019 at 07:04 PM.. |
I'd think the light fixture wiring might be long enough to reach the romex using wire nuts - if you can get the wires exposed and free to use them.
Another option - there is a product made by Tyco that allows a romex splice without the use of a junction box. They are "usually" allowed by local code. I've never used one but it will prevent you having a junction box right there on the wall - as you can't hide a splice in a junction box within a wall per code. I assume with the white jacket that's 14AWG. Here is a source: https://www.zoro.com/te-connectivity-non-metallic-splice-14-to-12-awg-300v-wt-cpgi-1116377-2/i/G3673695/
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Band.
Is it still legal if you can splice it with let's say. . . a 3" length of fresh romex that still fits inside the box?
+1 hidden boxes are most certainly illegal.
1983 SC Coupe 2020 Macan Turbo 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Band.
Well then the quick answer is to jam that schit in there and see if you can make it happen.
I don't know about that thing? |
Banned but not out, yet..
Hate to tell you but you also cut the ‘too’ in the title of your post one o too short and there is no junction box that can repair that.
Like others suggested get some hemostats and pull the wire out below the box, strip them and reinsert back into the box. If those are not long enough to use wire nuts, can the box be moved down a few inches?
An air cooled refrigerator. ‘Mein Teil’ |
Your suppose to have 6" of wire sticking outside of the box.
Just splice on some extra wire and close it up, no one will ever know. |
Someone mentioned use a utility knife and strip the sheathing back and strip the plastic off the actual wire and wire light directly to that. I have done lot of that doing picking up after someone years ago. Just have to have smaller hands. Perfectly legal with the exception of the 6" or wire sticking outside the box. I think it was 7" if the inspector wants to nitpick.
It is so common to wire on extensions that they call them pig tails. You can strip the wire back and twist the two wires together with dikes before you put the wire nut on.
It is a lot easier than it looks. If you fail, cut in a box lower in the wall and put in a switched outlet. It is like a junction box, except it looks like it is supposed to be there. This stuff is a lot harder to think about than it is to do. |
You might try Wago connectors. They might be easier than trying to wind on wire nuts.
John __________________________________ '79 911SC Targa (Sold), '76 912E (Sold) '98 Jeep TJ Wrangler, '17 Lincoln MKX |
I see you
Why is that so? Enquiring mind query.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
UnRegistered User
Simply because you must be able to access all connections and splices.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
The Unsettler
Looks like you can pull wire out of junction box and back out between box and sheetrock.
Should gain you at least another inch or more of working room. Butt splice on another length of wire and feed back into junction box.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
