LinkBack | Thread Tools | Rate Thread |
The bigger issue for me is I have a SWG and that just adds to the number of things to break. In addition to routine maintenance, there is always a pump, a filter, a skimmer, a float, a cleaner, a controller, a cover, a cell, a leaking pipe, etc, etc, etc that needs to be fixed it seems. And just when you've replaced damn near everything and are ready to enjoy, summer's over and it's time to winterize ![]() Cheaper and less painful to just have a close neighbor with a pool!
1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
65 ppm is fine. I used to keep mine at 80 to 100.
Ecosmart user here, chlorine free ... odor free...still can turn your blond hair green tho.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
I got my new Stenner pump hooked up today. What a disappointment this thing is.
The motor runs all the time (not quietly) and the pump rollers only engage on occasion with a loud click when it needs to meter out fluid. Sort of like leaving your car running in the driveway at 3000rpm just in case you need to go for a drive later. I guess I'll use the tank and re purpose a dosing pump I used have on an aquarium. I feel like an idiot for throwing away so much money on this thing. |
[QUOTE=greglepore;10491875]Ecosmart user here, chlorine free ... odor free...still can turn your blond hair green tho.
Copper and whatever sanitizers you're using attached together turns hair green. If you use a copper base algaecide stop! Metal in pool water doesn't get filtered out.. |
Brew Master
I've never had a problem with my pool turning blond hair green. My youngest daughter has the blondest of blond hair and it never got that light hint of green like it does at the local pool.
Nick |
This is a game I have played for a very long time. If you do it right, pool maintenance only requires about 15 min per week to keep the pool clean and sparkling, with no chlorine taste, smell, or other negative side effects. Test the water weekly and pay attention to the results. Adjust dosage as needed. If you ignore the pool it will get ugly and swimming will get pretty uncomfortable.
My recommendation: K.I.S.S. -Get an auto cleaner, a VS pump, and a good quality filter system, and run it long enough. - Use 3" tabs for residual chlorine levels and shock treat monthly, or after a swim party in summer with liquid. Test every week and adjust your dosages as needed. Adjust pH as needed maybe once a month or less. After 20 years working with salt chlorine generator systems I am less enthusiastic about them. When everything is working perfectly they do work but they are very expensive compared to traditional CL2 methods. They do require a lot of cleaning, fiddling, and repairing when the cell scales, the cell fails, the board fails, the flow switch fails, and if you ignore them they are very scale forming and will quickly make the pool very uncomfortable to swim. Certainly more expensive and every bit as labor intensive as not owning a salt system. There are just as many green pools out there with failed salt systems as green pools out there with failed maintenance routines. Most other alternative sanitizer methods work well as long as you are diligent with your maintenance routine but are 5-10x more expensive to use. Whatever sanitizer you choose, test weekly and be diligent with your routine. This is far more important than whether you choose traditional Cl2, salt chlorine generator, Biguanide, mineral, ozone, UV, or any other sanitizer. They are only as effective as the person applying the technology.
2009 Cayman PDK With a few tweaks Last edited by Cajundaddy; 06-27-2019 at 01:40 PM.. |
Brew Master
Seems appropriate to revive this thread in light of the "chlorine shortage". I saw a thread in PARF about a shortage of chlorine. I haven't bought my supply of chlorine for the season. I went to Rural King to buy some and they were sold out with a sign that read "limit 2 cases". So the panic buying will be here for pool shock.
I bought a new SWG system for my pool today. Circupool RJ30. Has the same chlorine generating capacity as most systems rated for a 40,000 gallon pool.
Nick |
