Puny Bird
Mark Henry's Avatar
The '06 4s I'm rebuilding looks like yours, customer's doing the full LN treatment, plus just about everything else on the greasy side.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-24-2019, 11:58 AM
MBAtarga's Avatar
You cannot rebuild your way out of the design flaws in that motor. Those years are time bombs and not eligible for the replacement IMS kits out there.
Replacement IMS kits are certainly available! (LN Engineering for one source.)
Bore scoring is another issue however.....
Mark
'83 SC Targa - since 5/5/2001
Old 06-24-2019, 02:22 PM
What is causing the bore scoring? Bad rings, poor cylinder material?
Bummer Rob, it's a nice looking car. And it sounds like you were having good fun with it.
All the best in getting it fixed well.
Cheers Richard
Old 06-24-2019, 03:00 PM
Team Minneapolis
speeder's Avatar
I should have qualified my statement; you cannot replace the IMS w/o completely tearing down the engine. So you could do it once on this one. Not sure what you would do when that wears out in 40k miles, (or whatever the service life is).
This is a sad example of how these engines are completely unsuited for track use.
Denis
Old 06-24-2019, 04:11 PM
Speeder is wrong.
Go do a search on Rennlist, there are a number of rebuilders out there that can do a proper rebuild up to and including full track use. I will concede its not cheap.
Old 06-24-2019, 04:29 PM
Canadian Member
911Rob's Avatar
Thanks!
Old 06-24-2019, 04:51 PM
MBAtarga's Avatar
Sorry - but you're wrong again. European Parts Solutions has a kit that allows replacement without disassembly. It's not cheap to purchase, but can be rented for $400 ($1500 core charge.)
Porsche IMS Bearing Tool Kit - Intermediate Shaft Bearing Repair Tool Kit 996, 997, Boxster, Cayman — European Parts Solution
There's a video (can't get it to embed here) on that page that shows the issue and the product in use.
Mark
Old 06-24-2019, 06:49 PM
Team Minneapolis
speeder's Avatar
Originally Posted by ltusler View Post
Speeder is wrong.
Ok, how about in stock form? Of course they can be improved or fortified at great expense, (what engine does this not apply to?), I was referring to the way they come from the factory. BTW, I do not dislike the cars. I like them a lot. But unlike the earlier and later cars, they are not suited for track duty out of the box. Sorry.
Denis
Old 06-24-2019, 09:52 PM
Gon fix it with me hammer
svandamme's Avatar
bore scoring can be re-mediated with sleeves.
And prevented with improved cooling
Make sure you have the 70 C thermostat so you get cooler coolant to your engine.
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-24-2019, 11:44 PM
MBAtarga's Avatar
There's lots of speculation as to if the low temp thermostat does what some claim it does. It opens earlier (at the lower temp) - but it doesn't miraculously allow the engine to run cooler.
Mark
Old 06-25-2019, 04:50 AM
RedBaron's Avatar
I assume you would want to do a rebuild with the LN Nickies? This way they are nikacil plated like the good ole aircooled engines!
Old 06-25-2019, 05:47 AM
Almost Banned Once
sc_rufctr's Avatar
Wheeler dealer make it looks easy.
- Peter
Old 06-25-2019, 05:59 AM
svandamme's Avatar
997 doesn't have an accessible IMS
Stijn Vandamme
Old 06-25-2019, 06:16 AM
