Puny Bird
The '06 4s I'm rebuilding looks like yours, customer's doing the full LN treatment, plus just about everything else on the greasy side.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
![]() Bore scoring is another issue however.....
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
What is causing the bore scoring? Bad rings, poor cylinder material?
Bummer Rob, it's a nice looking car. And it sounds like you were having good fun with it. All the best in getting it fixed well. Cheers Richard |
Team California
I should have qualified my statement; you cannot replace the IMS w/o completely tearing down the engine. So you could do it once on this one. Not sure what you would do when that wears out in 40k miles, (or whatever the service life is).
This is a sad example of how these engines are completely unsuited for track use.
Denis |
Speeder is wrong.
Go do a search on Rennlist, there are a number of rebuilders out there that can do a proper rebuild up to and including full track use. I will concede its not cheap. |
Canadian Member
Thanks!
Porsche IMS Bearing Tool Kit - Intermediate Shaft Bearing Repair Tool Kit 996, 997, Boxster, Cayman — European Parts Solution There's a video (can't get it to embed here) on that page that shows the issue and the product in use.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? Last edited by MBAtarga; 06-24-2019 at 06:53 PM.. |
Team California
Ok, how about in stock form? Of course they can be improved or fortified at great expense, (what engine does this not apply to?), I was referring to the way they come from the factory. BTW, I do not dislike the cars. I like them a lot. But unlike the earlier and later cars, they are not suited for track duty out of the box. Sorry.
Denis |
Gon fix it with me hammer
bore scoring can be re-mediated with sleeves.
And prevented with improved cooling Make sure you have the 70 C thermostat so you get cooler coolant to your engine.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
There's lots of speculation as to if the low temp thermostat does what some claim it does. It opens earlier (at the lower temp) - but it doesn't miraculously allow the engine to run cooler.
I assume you would want to do a rebuild with the LN Nickies? This way they are nikacil plated like the good ole aircooled engines!
Almost Banned Once
Wheeler dealer make it looks easy.
- Peter |
997 doesn't have an accessible IMS
