-   -   Any Recommendations for getting rid of moss on roof? (http://forums.pelicanparts.com/showthread.php?t=1034347)
Tidybuoy 07-10-2019 09:28 AM
My roof is fairly new at 7 years old with 50yr asphalt shingles. It's starting to get some moss on the shingles. Anyone have a recommendation for getting rid of this? I don't want to spray something that runs off and kills my plants on the ground. I also thought about using a pressure washer but don't want to damage the shingles.
Photo of Shingles - before moss build up (to show type of shingle)
http://forums.pelicanparts.com/uploa...1562779644.jpg
gizmofixer 07-10-2019 09:49 AM
i used HD deck cleaner with the pressure washer on medium pressure.
This worked well, then a roofer told me a secret.........
install a strip of copper sheathing under the top cap, it should show about 3 inches.
The miniscule copper element in the runoff will prevent moss and lichens from growing.
Works like magic.........no more washing the roof!
Scott Douglas 07-10-2019 09:49 AM
Wow, moss on a roof in Fresno?
Never would have thought you'd get that kind of problem there with as hot as it gets.
This must be on a north facing roof which is shaded almost constantly by trees, if I was guessing.
Sorry I don't have any suggestions.
Scott Douglas 07-10-2019 09:50 AM
I bet that copper trick works slick, Paul. Just like driving a copper nail into a tree if you want to kill it.
RWebb 07-10-2019 10:25 AM
use a spray with iron sulphate etc. in it - should only kill the moss, which is very sensitive to ferrous compounds rel. to vascular plants
that will kill it; not remove it - pressure washer will do that but abrade the shingles somewhat
a strip of Cu along the roof line works great long term ($$$)
maybe trim some trees to get more sun in those areas - moss will grow if the environment favors... moss
pwd72s 07-10-2019 10:30 AM
This product has worked for me for decades. Beware of copper, can corrode galvanized or aluminum gutters. This a zinc compound...but the runoff can damage lawn grass. Never had any shrub damage, but won't say it couldn't happen.
https://www.corrys.com/all-products/moss-b-ware
LWJ 07-10-2019 10:34 AM
Here in the PNW, we get moss. Lots of it.
Iron and copper are typical remedies. You can also use laundry detergent sprinkled on the roof. This may be problematic with the down stream water shed. Not certain of your situation.
It works very well. It will kill the moss but then you may wish to blow / wash the moss off.
Good luck from moss country to moss country!
RWebb 07-10-2019 10:38 AM
best thing would be to start a moss rant thread in PARF
start with some name calling about them being "primitive" plants and how they suck compared to angiosperms
Dantilla 07-10-2019 10:51 AM
It works very well. !
While very effective, and much less expensive than products marketed as moss killer, laundry detergent will degrade the asphalt in the shingles. Over time, the granules will begin to lose adhesion and end up in the gutter.
Clint Lando 07-10-2019 10:53 AM
http://forums.pelicanparts.com/uploa...1562784817.jpg
KFC911 07-10-2019 11:03 AM
The Stones ARE on tour...have 'em come roll around on yer roof :).
Clint Lando 07-10-2019 11:07 AM
no roof
tent
Rusty Heap 07-10-2019 11:08 AM
this is my go to product.
shake it heavy dusting up at your ridge crest.
right before a light drizzle.
zero issues.
zinc flashing up top works too.
wdfifteen 07-10-2019 11:16 AM
Spray and Walk Away. I’ve used it on a couple of projects. Apply with a pump sprayer, so little to no run off. It may take weeks for the moss to go away, but it doesn’t come back.
https://www.homedepot.com/p/30-Seconds-1-Gal-Cleaner-Spray-and-Walk-Away-100506799/202897313?MERCH=REC-_-PIPHorizontal2_rr-_-206409694-_-202897313-_-N
porsche tech 07-10-2019 02:31 PM
Wet it and Forget it is a good product and easy to use.http://forums.pelicanparts.com/uploa...1562797796.jpg
KFC911 07-10-2019 03:07 PM
Originally Posted by Clint Lando (Post 10519309)
LOL..I missed that right before I posted before....yeah you right!
drcoastline 07-10-2019 03:14 PM
Moss is a moisture issue similar to mold. Cut down all your trees so you get more sun light, change the PH buy a commercial moss control agent which changes the PH.
RWebb 07-10-2019 03:16 PM
also... napalm - kill it good
Tidybuoy 07-10-2019 03:24 PM
I live in a very heavily tree'd area. You can slightly tell in my photo above.
The moss on my roof appears mostly dead as we are now having summer heat (100+degrees). So now, it's more like a crust at the edge of the shingles but it will become slimy once winter shows up. I also have a lot of brick walkways and patio which always get moss in the winter. I've tried roundup but the moss comes right back.
HobieMarty 07-10-2019 11:03 PM
Bleach mixed with a little dawn dish soap, spray with low pressure. The bleach will kill the moss, the dish detergent gives the bleach a clinginess so that it won’t run off quickly. Rinse with low pressure. There are videos on YouTube explaining how to do this.
