-   -   Cracked skin on hands - help (http://forums.pelicanparts.com/showthread.php?t=1048334)
Tobra 01-01-2020 03:42 PM
Milt, do you pull/push the edges together or just hit them with the superglue?
It is possible to take two small pieces of tape, attach one on either side of the cracked area and pull the edges together. This is particularly effective if you use some sort of skin adherent, such as tincture of benzoin or some other skin prep. Sticky part of a bandaid cut into strips works well as a make shift "butterfly"
dependencies 01-02-2020 06:18 AM
Originally Posted by Zeke (Post 10703415)
Works for me. On heels and fingertips just under the nail. Sanding down helps a lot too. With both, they don't crack open again and again. They heal instead.
another vote FOR superglue here, when the tip of fingers beside nail has split I've been glueing the edges together which holds it for a couple of days while it heals,
(usually caused by working in the rain which I understand is due to an amount of acid in rain drops, as opposed treated water in tub which has been processed to remove it as I understand)
https://i.postimg.cc/xCT4LT35/Screen...t-14-25-15.png
dependencies 01-02-2020 06:29 AM
Tobra; I push the edges of split together (if possible without sticking both those finger to split at same time)
but as long it forms a blob/bubble inside and above split it appears to have worked OK so far at least.
OUR A&E dept use a 'sterile' version apparently instead of stitches on some wounds
Baz 09-10-2023 10:04 AM
See also:
https://forums.pelicanparts.com/off-topic-discussions/1146061-moisturizer.html
Jeff Hail 09-11-2023 12:01 AM
Originally Posted by stevej37 (Post 10699591)
Made from sheep pimples (fat lipids and oils secreted by the sebaceous glands) and 8-Hydroxyquinoline, wax. Mild fungistatic, bacteriostatic, anthelmintic, and amebicidal action. Good for the mitts and the vulva. Traps that moisture and locks it in.
