Retired, finally
SiberianDVM's Avatar
Gas pump won't fill portable gas can?
Never had this happen before: tried to fill plastic gas can with 89 non-ethanol for my small motors. The pump just wouldn't pump it into the can. Tried it in my car, worked fine, so must be some kind of ground sensing?
Is there a workaround?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 04-02-2020, 06:34 AM
canna change law physics
red-beard's Avatar
Does the pump have the seal collar? I've had to manually pull back the seal collar on the nozzle to fill some gas cans.
James
Red-beard for President, 2020
Old 04-02-2020, 06:43 AM
^That^. I think the nozzle's accordian cover needs to be pushed back before the pumps will pump.
If it was circumcised, then it's something else.
Old 04-02-2020, 07:00 AM
^ Yes, Pull back the vapor recovery seal as far back as it will go. This will allow the gas to flow.
Old 04-02-2020, 07:14 AM
Counterclockwise?
What is that cover?
Never seen one up here.
Rod
1986 Carrera
2001 996TT
Old 04-02-2020, 09:24 AM
Originally Posted by 911 Rod View Post
What is that cover?
It's supposed to collect the fuel vapor/fumes instead of allowing them to float into the atmosphere. It's probably much more prevalent in areas that get hot (causing fuel to evaporate) or maybe very low humidity.
I remember as a kid, if you filled a car REALLY full and then parked in full sun in the summer, it was possible for the fuel to expand due to the heat enough for fuel to weep (pour) out of the fuel inlet around the cap seal.
Old 04-02-2020, 09:28 AM
Retired, finally
Nope. It was a new pump but plain metal nozzle with the metal wire wrapped around it. I'll try a different station next time.
Old 04-02-2020, 04:01 PM
wdfifteen's Avatar
What is that cover?
It keeps gas fumes from coming out of the tank so you can smoke while you fill up.
Old 04-02-2020, 05:15 PM
Make sure the nozzle is facing down, and there is no fuel covering the vent hole at the nozzle tip.
Old 04-02-2020, 06:22 PM
Retired, finally
It must have been that attitude sensing ball, which may make for a big problem the next time I have to fill the old 911.
Old 04-03-2020, 03:30 AM
beancounter
jwasbury's Avatar
Awesome! I’m gonna try that next time
Old 04-03-2020, 06:06 AM
