Evil Genius
Gas Pressure Washers Suck regardless of brand
What does it take to get a Home Residential heavy duty pressure washer to last???
Simplest device in the world. A gas motor, a pump, and a wand/cart doo-hickey of some odd-ball combination. RANT on my soap box. I consider myself an above average small engine mechanic. I own 5 acres so my projects tend to be bigger than a condo/apt owner using a $199 electric unit. For the life of me I can't keep a pressure washer fully functional for more than a couple of home projects, deck / driveway / fencing. I've had 2500-4000 psi units. $400-$1000+ Cheap ones and expensive. AR pumps made in Italy to CAT pumps. Honda Motors vs Mystery Engines. I don't mind rebuilding carbs, installing new o-rings, and dig in deep repairs. But holy crap this sucks................ Items that ALWAYS fail : soap injection suction pre-wash pump o-rings to keep pressure Pump by-pass pressure valve while at idle. Wands falling apart. Gas engine constant carb issues off my soapbox, but low low hour units seem to die a early premature death of some sorts. grrrrrrrrrr !#$%#^^%$&*^()&* I'm about to go to Harbor Freight to just get a cheap 4000 psi with cheap AR pump and cheap Predator generic motor...............$799. BUT FOR SURE get the extended warranty simply to return it 3 times a year so I always have a fresh one at the start of a major project............ are we really at that level of disposable society.??? ![]() ![]()
Life is a big ocean to swim in. Wag more, bark less.
Yep, dealing with carb issues with mine for the second time in less than a year. Could be the ethenol in gas that I am using. Super sucky though.
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates 88 coupe |
Guess I got a good one before they went to crap. Bought mine at Costco in '05/'06 and have barely done any maintenance in all this time. Still starts up and runs all day if needed.
1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML |
Retired, finally
Just bought a Karcher yesterday (my electric Karcher has lasted more than 20 years) and then went on a hunt for non-ethanol gas.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
Model Citizen
I've had mine a long, long time. At least 15 years. About the only maintenance I ever do is make sure to run the gas tank dry at the end of every session. Bone dry.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Platinum Member
I've had my Karcher a long time. Last year pump went bad, but motor was good, so i bought a replacement pump on amazon, $70.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
. Hell, even non-ethanol 93 ain't what it used to be (even w/ Stabil added). I've had more issues the past year than ever before with my 2 cycles...some I've had forever.That said....my new go to chainsaw doesn't have a carb....big
canna change law physics
The Home Depot special with a Honda Engine has been doing fine. I need to get the carbs fixed on a couple of generators...
What is the secret? Viton instead of Butyl-N o-rings?
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
1 Don't run anything other than water through the pump !!!
2 Always get any air out of the hose/pump before starting !! 3 Don't let it run in bypass for more than a minute !! 4 Chemicals will eat the pump o'rings and the hose o'rings !! 5 Always use stabilizer with Ethanol gas or find Ethanol free gas !! That's a start for now, Mine is 20 years old and still GREAT.
You might have a lot of sand in your water. Simpson makes a filter that you can use on the intake side. There is also a lubricant that you add during storage to help the pump seals last. I have a Simpson water blaster that has lasted over 10 years now.
Evil Genius
This may be the unit..............good old HF.
$899 I found a $100 off coupon, for $799. 4000 psi with a vario pressure reg on the wand. https://www.harborfreight.com/4400-psi-42-gpm-13-hp-420cc-commercial-duty-pressure-washer-epa-64931.html Northern and Northstar are $$$. the next price point seems like Belt driven in the $1600 range. Costco would have a return policy but may not stock the unit. Lowes and HDepot about the same.
Evil Genius
Those have always been my 5 golden rules too................good list!
Fleabit peanut monkey
Cold water only.
1981 911SC Targa |
Recreational Mechanic
I ditched my gas pressure washer a couple years ago and went to a Karcher K-series electric and have not looked back. Very happy with it, much more reliable than my gas Honda/Karcher washer that it replaced.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Platinum Member
I think it's the alcohol in the gas. Some fuel lines/rubber swell shut, others disintegrate.
I have a Simpson with Honda engine. I run the expensive gas from Menards 50:1 in it. Seems to work well. Starts right up sitting all winter in heated garage.
1980 911SC Targa 3.6L |
I've owned and used a Northern Tool pressure washer with a Honda engine for at least 15 years now.
Works perfectly ever time. I learned quickly to shut the water off and release the pressure when starting. Fires right up every time.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
I had a no name and the pump was always funky leaking the oil out all over the chassis. The carb? Buy a new one for less than $15 shipped.
I had one for probably 10-15 years. I think it was a Rigid with a subaru motor, 3x00 psi, I want to say 3600 or 3800, but I can't remember for sure. It didn't get tons of use, probably 10-15 times, but it always started despite being neglected.
Plastic Honda bag with O-rings, gaskets, etc. - $15 Quality (Made in Japan, but not Honda) replacement carb, shipped - $15 |
