Fleabit peanut monkey
Another semi-related story. Product inventory audit at Marcus Hook, PA refinery.
Was on top of a storage tank of some really light specific gravity product. Refinery guy says, "You will sink like a stone in this to the bottom". Mr Big Brain (me) asks what if you do the treading water motion? Guy says you can do that while on the way to the bottom.
1981 911SC Targa |
It's a lot easier to float in sea water than lake water, lot easier.
Motorsport Ninja Monkey
![]() When I'm vertical in the water I float at neck height in sea water in the Dead Sea I floated at chest height ![]() Very strange to swim in as the increased buoyancy even made hard to roll over from back stroke to front crawl too Water tasted nasty, real nasty and I soon found out where I had any chaffing or cuts on myself
Wer rastet, der rostet He who rests, rusts |
I have never been able to float...at 5'10, 185#, I am thin, but muscular (which weighs more than blubbery fat). I have never had problem with any PFD keeping me afloat however.
Make Bruins Great Again
Man boobs? Nope. More fun if the mrs is doing the jumping jacks with those.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Edministrator
A body covered in chains with weights will not present any buoyancy problems. Or in the trunk of a car. That's just what I heard.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Control Group
You want to run the chain through the pelvis, if you want to be sure it stays down there. If there are enough crabs, it does not matter.
The mob used to dump bodies in Lake Tahoe. It is cold enough gas never forms in the tissue so the body does not float to the surface, or that is what a fellow in the trash disposal business told me anyway.
She was the kindest person I ever met |
Whereas when someone gets drowned in the sea they tend to reappear about five days later. |
Flotation devices usually clearly state what size of person they are rated for. They are designed to keep your head above water, and not much else. Dress for the water, don't carry things that will weight you down. Put those things in an air tight duffel, and they may float anyway. Common sense will tell you what to wear and carry. |
